Featuring improved brightness, a new intuitive touchscreen interface, new synthetic vision display, and an even lower price point, the D3 is the most advanced portable safety device Dynon has ever made.
D3 lets pilots supplement their unreliable legacy instrumentation with an affordable, portable electronic attitude indicator that works. The D3 features the same reliable, proven AHRS engine from Dynon’s best-selling panel-mounted products for experimental, light sport, and type certificated aircraft.
The D3 comes with a complete set of accessories, including home and airplane chargers, an optional external GPS antenna, and two unique mounting options. Both the included cockpit mounting options require no tools, allowing the D3 to be deployed in any aircraft with no FAA approval. The D3’s list price is $995, but at introduction pilots may find it available as low as $879 from authorized Dynon dealers.
The D3 Pocket Panel is a portable situational awareness device, allowing pilots to add a modern, affordable backup safety device to supplement their often-unreliable legacy certified instrumentation. The D3 comes with two portable mounting options, no tools required. Because it does not require modification to the aircraft’s design, no regulatory approval is required to use a D3 Pocket Panel in any aircraft.
The first mount included is a RAM® suction cup mount. The second is a 3-1/8-inch portable “pinch” mount that allows the D3 to be easily mounted in an empty existing instrument panel hole without any fasteners.
