Leaky fuel caps costing me $$$
I have 1964 PA-28 Cherokee that has a consistent problem of losing fuel from both of the gas caps during climb out. I have replaced the rubber seals under the caps, and even purchase new caps from Spruce, but still find blue streaks on the wings after each flight when I land. An obvious answer would be to just not put as much fuel in the tanks and just fill to the tabs instead of topping off the tanks, but I do make some pretty long cross country flights where I need the fuel, so I usually keep the tanks full. I have searched the Internet for different fuel cap solutions, hoping to find something that is flush mounted and/or seals tightly to prevent this from happening but I haven’t been able to find anything but the stock caps.
Does anybody know of a solution to this problem, and where I might find a better gas cap?
Brian Lucas
N6234W
‘64 Cherokee
Brian Lucas
N6234W
  • I am not an expert, but I think I remember hearing that there are two different thicknesses on the available rubber seals. Maybe there is a different sized seal that you need.
    Jim
  • I’ve only been able to find one size of seal through Spruce or other retailers, and have tried a couple different ones to see if they’re just manufactured differently, but they still don’t fix the issue unfortunately.
    Brian Lucas
    N6234W
  • Hi, there are two thicknesses and I've purchased the wrong ones twice on two different airplanes. Check your parts manual for the right one. https://www.aircraftspruce.com/catalog/eppages/gasket08-13788.php?clickkey=3008203 https://www.aircraftspruce.com/catalog/eppages/gasket08-13787.php?clickkey=3008203 Here they are, two different thicknesses.
  • Scott, the second link you sent isn’t the correct diameter size and won’t fit my cap. I haven’t been able to find a gasket thicker than 1/16” with the correct 3” OD x 2” ID size.
    Is there not a better fitting cap on the market that locks in place and seals properly?
    Brian Lucas
    N6234W
  • Hi Brian,
    To the best of my knowledge there are no alternate sources of tank covers other than buying them directly from Piper/Aviall. I've looked for years and haven't found anything. Perhaps someone else has. If I remember right, Piper charges a couple of hundred for new ones.
