Turbo lance II
I am the new owner of a 1978 lance II turbo. I have a puzzling question for anyone. Once at altitude using lean find on the engine monitor the fuel flow leans back from about 22 GPH to about 15GPH and as I continue to lean it begins to increase back to 21 GPH before it starts flashing indicating peak. Lean find starts flashing and as I go to 100 rich of peak it goes from 21 GPH back down to 15GPH. Anyone have any idea how this can happen? Im not sure what would happen if I keep leaning to LOP because I haven't tried it. Low time engine with around 15 SMOH.
Craig
Craig
You did not mention which engine monitor you have. My advice would be to go to the engineer at that manufacturer and get feedback direct from them?
Also, my gut says you may want to stay away from much leaning on this freshly OHC'd engine. I think running it rich during the break-in period is probably the better plan.
Again, consult with the OHC shop and see what they say? Thanks! Bob Hart www.AvionixHelp.com
http://www.piperowner.org/memforums/topic.html?id=151567
I had read that post and was hoping that you would weight in with some magical solution! When you say "I had the same problem" does that mean that you fixed it? Did it continue or just change? Someone told me the ships FF gauge is a pressure reading correlated to indicate FF and that would have to be the culprit. Makes sense.
Craig
PS: the FF Gauge explanation doesnt quite convince me, but will continue to research
Regards
