Parts help needed piper arrow
I have a 1973 arrow 2. I need a cam lock fastener for the air cleaner housing cover. The parts Manuel calls for either the 2600-114w or the 2600-123w. One how can I tell which one I need and second where can I get these parts? Thanks for any help.
Try Piper Parts Plus in TN. (866) 897-2787 or (901) 259-6136
If you give them your serial number, They should be able to tell you which one you need.
Good Luck ... Bob Hart www.AvionixHelp.com
Thanks, I figured out that it requires two 114w and one 123w. But I will call them and see if they have any. Thanks
