Cherokee 140 Front strut leak in winter
                    Can someone tell me if you are having similar problem. In the winter I like to preheat the engine by putting a blanket on top of the cowling and using a heater blow warm air into the front intakes, it does a great job BUT a few times I had a problem. I put everything away start the plane go for a flight and when I land the front strut is completely deflated.
I am wondering if by me heating the engine compartment the warm air is making the top of the strut expand and the piston staying cold since is outside of the cowling the difference in temperature creates a gap enough to leak. Any thoughts? If this is the problem how can I preheat without effecting the temperature difference on the strut?
