best location for mounting an NSD 360 HSI Flux dectector
                    installing a slaved NSD 360A HSI and looking for the best place to locate the Flux Detector?  Everyone says L Wing keeping the Flux Detector away from Ferrous metal ( 18 inch radius). is this the only choice? I have a 1968 Piper Arrow.
Steve
Steve
NSD-360 install manuals are "illusive" on-line so here's the basic instructions from the Bendix King KCS-55A HSI for their KMT-112 flux detector.
Simply stated, the tail is the other option vs. the wingtip. Your installer should be the source of this decision and therefore responsible for it. If your doing it yourself, then you'll need to fugure it out. This is where an installer's experience comes in. You can see, the manufacturers don't help alot!
The KMT 112 Transmitter detects the horizontal component of the earths magnetic field and
transmits them to the KI 525/525A Indicator for use as long term correction information.
2.5.2 MOUNTING
The KMT 112 should be located as far as possible from all sources of local magnetic disturbances
such as engines, electrical cables, or radio equipment. A wing tip or tail section location will usually
be satisfactory. The use of a hand held compass can be helpful in determining if the selected
area is free of magnetic disturbance. The mounting surface should be such that when the aircraft
is in level flight the mounting flange of the KMT 112 will be level within ± 2 degrees. The unit
should be secured per Figure 2-4 with the three #6-32 non-magnetic screws and associated nonmagnetic
hardware that are provided with the unit. Using the connector provided connect the wiring
to the unit as shown in Figures 2-9 and 2-10.
(these figures won't help you)
Good Luck Bob Hart www.AvionixHelp.com
