AMMETER READING ON PIPER LANCE
                    GROUND CHECK IS NORMAL, GET A GOOD CHECK BY TURNING ON PITOT HEAT, LANDING LIGHT IS LED SO IT NO LONGER GIVES MUCH OF A JUMP.DURING RUNUP AT 2 2000 RPM STILL NORMAL.  WHEN RETRACTING GEAR ON TAKEOFF AMMETER SHOWS BIG JUMP, ONCE GEAR IS STORED,  PRESSURE SWITCH SHOULD SHUT OFF PUMP.  NOW IS WHEN I NOTICE PULSING ON AMMETER, PULSING GOES AWAY WHEN GEAR IS EXTENDED.  ANY IDEA WHAT IS GOING ON HERE?
If left unattended, the pulse will eventually become more continuous. Eventually wearing out the motor in the hydraulic pack (from extended use) or from loss of oil. My Lance has had two hydraulic packs in its days.
The first one was from the electric motor just being toasted. Brushes melted to the armature and it was a mess (just wore out). In your case brush wear or metal to metal would definitely explain high amp reading. If you (or your mechanic) have never looked in the brush cavity of the hyd power pack motor, I encourage you to do so very soon.
Then I sold the airplane and bought it back 10 years later. Looking in the logs I see the previous owner had changed a power pack too. Upon investigation, I discovered it was from a leaking cylinder that had caused the pump to run almost non stop.
I am guessing you will be in the same boat over time unless you find your leak.
Hope this helps.
Jeff
DON'T FORGET TO RESET THE BREAKER BEFORE LANDING
I've had a Seminole and three Seneca's, all with a power pack. When the gear system has a leak and the hydraulic pressure decreases beyond a certain point the pump cycles, just as you surmise. Your A&P can fix this... good luck and let us know how you make out.
N344TB
Forum Moderator
