PA28-140/150 (1969 Piper Cherokee)
                    I own a 1969, Piper Cherokee (PA28-140 w/150).  The plane is in great shape, well maintained, hangered at Meadow Lake Airport outside Colorado Springs and has not flown much over the last 2 years due to personal reasons.  I know temp./alt. might impact actual oleo strut normal extension (3.25 inches nose gear and 4.5 inches main gear), however, today I noticed when I went to check on the airplane that one side of the main gear seemed a little higher than the other side, a difference of maybe 1 to 1.5 inches (difference between the main gear oleo extension).  The gear whose oleo appeared higher, I checked the wing tank, it was almost empty, the other wing had about 1/4 tank of fuel.  Can someone advise if this is normal?  If not, is this a quick or cheap fix (relatively speaking)?  I have read about nitrogen being used, leaky seals (I have not seen any leaking), etc.  Please advise soonest, I am having my biannual flight review soon, in this airplane.  The aircraft annual was due in April, I am having it done in late June.  Thank you.
Stand by while I check with our A&P.
"I would say it's normal. I'd top it off (fuel) and re check extension, if they are uneven I'd have the local shop service per the MM with dry nitrogen.
Also I use a product called strut guard to clean, lubricate, and preserve the chrome. It's a spray and it will go a long way to saving the seals in the strut and the chrome from being gouged etc as well as rust. WD40 could also be used."
~Erich
