Tempest or Champion
                    Was wondering from Experience from others Which is highly recommended from you Guys/Gals Tempest or Champion? I changed my plugs about 100 hours ago from Tempest to Champion because thats all i could get locally at the time. Seems like when engine warms up over time that engine seems to vibrate a little. Was going to change back to Tempest next week and see if there is a difference. Has anyone else experience this when changing the plugs? Timing and points Checked good.
This is a really good question and I'm embarrassed to say that after 50+ years of flying, I don't know! I'll tell you what I'll do; I'll send this topic off to our A&P Erich Rempert and have him weigh in. Stand by!
I only use champion filters however
Hi and thanks for the update. I'd say you have a "gift" for engines
  Keep on using it!
I have read on the savvy aviator site that the champion plugs have an impedance issue brought on by cheap internal parts. So even though it is just a spark not all sparks are as bright.
I have seen the light! And it is Tempest
the new Champion plugs appear to be better, the old ones with the suspect resistance have the screwdriver slot down the bottom of the HT lead hole, the new ones have no screwdriver slot and seem to be ok. time will tell
Thanks so much for the update.
