battery trickle charge
How can I set up a trickle charge on my warrior since the battery is underneath my back seat?
Also, I have the external power receptacle, I doubt it, but can I use that in any way?
thanks
Kevin
thanks
Kevin
http://piperowner.org/talk/discussion/153689/aviation-vs-automotive-battery-tender-minder#latest
There is some information in this thread that may give you some insight. If not, there are some really knowledgeable members who I am sure will chime in shortly.
Jim M.
PA-28R-200
Based at BUU
ATC Chicago TRACON
Most if not all, of the direction needed is contained within that thread...Aviation specific battery tenders are the only way to go..
Hi Kevin,
And as the other members have already mentioned, check out the thread, it's very good.
Regarding the power receptacle, that's only for starting with your car battery, it's not connected to the ships battery.
