Officially joined the club with a 1964 Cherokee 180
Pre-buy came back with minor gripes. Needed new tires and nose strut serviced, so seller knocked off $1500 but was sold with fresh annual and IFR certification. Also turned up some interesting avionics history. It has the servos for autopilot, it had a 430 at one time and then a KLN90 which prior owner reported smelling smoke coming from it so pulled the breaker and had it removed. Plan to use for CPL training and for my wife to get her PPL and do some cross country flying especially after she retires as well. Since it has fresh IFR cert I'm not going to do anything with the panel for a couple years. Want to get a good idea of what exactly I want and where.
Unfortunately it will be next week before I'll be able to take her up until next week because of weather.
FickertFarms;
Welcome to the group! That's a beautiful bird, and a very capable platform.
If you have questions, post them here on the forum. There is a lot of knowledge, and the members are happy to share their expertise! Enjoy!
Ff,,,
Great starter bird. That should last u a long time with many possible upgrades. Carl
Nice bird 🙂
Hang on to the wallet, the upgrade bug is very tough to tame.
While on the topic of upgrades, unless there is a reason to keep the plane pant-less, consider looking for a set. Despite the additional weight, this will pay for itself with either 5 - 7 knots faster cruise speed, or less fuel for the same current cruise speed.
Oh, and a tip from experience. Consider adding carb heat for a little bit while in the pattern, and then make sure to turn it Off by the time of turning Final. Chances are good that the POH will indicate to leave the heat in the Off position for most / all of the RPM range (or, alternatively, is silent). Reasoning is that I have actually encountered carb ice on a regular basis in conditions when it should not have existed (per the POH) and a hangar neighbor encountered carb ice while on Final during the Summer. Two different engines, but both were PA-28s with carburetors. At worst, this simple task will prove worthless and add one routine to the workload, and at best it will prevent an underwear changing experience due to something that is not supposed to happen.
The carb heat on is actually in the typed out checklist the prior owner made, he owned it for 22 years. I'm going through the POH now and making notes as the air speed indicator is in classic MPH with knots on the inner ring.
It has all the mounting hardware for pants and must have at one time. No idea what's happened to them in the last 60 years as plane came pantless to prior owner in 2003.
The IA that has worked on it the past 15 years said if I don't care about paint the flight school he works for has a set they are willing to sell for $400.
Wife is going to be working on her PPL as well since we have planes would be a good idea to know how to land it in case of in-flight emergency. We're in good health, but ain't getting any younger. Although I also have an Ercoupe that she could learn to fly on...
Excellent response from jacobsja, I agree 100%.
If you can get a set of wheel pants for $400, I'd jump on that deal! My POH (PA28-161) stated a 7 kt speed increase with wheel pants. A before/after test yielded a 6 kt gain in a slight climb, so 7 kt was right on the money.
Have the plane weighed after the installation of the wheel pants. They'll add about 15-20 lbs or so. Save the airplane weight prior to wheel pant installation, you'll see why below.
There are good arguments for removal of the wheel pants when flying from grass strips or during the winter. Snow/ice can pack inside the wheel pant and lock up the wheel during winter ops and uneven ground on a grass strip can damage the pants.
Any time you remove or install the wheel pants, make a log entry and note the change of aircraft base weight. This is why the weight prior to wheel pant installation was saved. Use the appropriate number for your weight/balance calculations.
Seriously, if the flight school wheel pants are in good shape, buy them!
+1 on the wheel pants! If the paint on the schools wheel pants is not that pretty, it won't cost much to just do the wheel pants, compared to the whole aircraft which looks great by the way! For sure the aircraft was repainted since 1964! By the way, I have used my 180 on grass and snow for 40+ years and never had an issue requiring removal of the wheel pants. If you operate in extreme conditions that is a different story but in temperate climates I do not think it will be an issue. You may want to remove them to put air in the tires though! That is a pain. If anyone has a trick for adding air to a '60s vintage Cherokee with wheel pants, please let me know!
Miss-matched paint on parts is no big deal. It enhances the theft deterrent qualities 😁
The set the flight school had for sale are solid white. I went ahead and picked those up.I have no idea what my plane's base color is exactly other than "beige". Maybe it was mocha tan originally? I can't find anything in the logs about when the main airframe was last painted. However I do have the paint colors used when the after market wingtips were installed and the cowl painted in 2000, which is "Gondola Blue". So I guess if I want to burn some money I could get the pants painted that color to match the tips and cowl.
Finally found the paint entry in the logbook. It was painted "Chrysler San Mateo Wheat" in 1995. However the Sherwin-Williams Gondola Blue that the cowl & tips are painted in is still readily available so will probably have the pants panted that color eventually.
