GX60 Removal
I have a GX60 mounted in my Dakota. I have loosed the locking screw and the unit pushes forward from the panel about 1/4 inch. I can move it slightly side to side but it will not slide out of the panel. Does anyone have an idea what may be causing it to bind or suggestions on how to get it to pull out?
It's possible the rack has incorrect screws that are binding the radio, I've seen that in the past. If the lock tab is completely clear of the rack, sometimes you can see that with a good flashlight and looking below the unit, you can just pull harder than you think you should. It will pop out, and again, if the lock is clear, no damage will occur. Just pull straight out to ensure no damage to the pins.
Tom Jackson
PA28RT-201, N3022U
Tappahannock, VA (KXSA)
A&P/IA, Private Pilot, IR/A
After turning the locking screw to jack the unit out of its connector and it slides forward that 1/4 inch, turn the screw the other way about 1/4 to 1/2 turn and remove the unit. Did that work for you? Some units work that way. Not sure about the GX60 specifically.
I've had luck in such cases by first removing the radio immediately below the one that's stuck. From there I can better see what is binding and correct it.
-DJ
Thank you for the suggestions. I have not been over to the plane to try these out but will definitely try them. I appreciate the assistance.
