Does Changing N Number Effect Aiirplane Value
Hi: Is it easy to change an N number? Can you change it simply because you do not like it? Also, if you change the N number, does that adversely effect the resale value of your plane, or have any other adverse consequences? Happy and Healthy New Year to All. Chuck
The bigger cost and hassel may be with removing the old ones and applying the new ones. If yours are still the small numbers, they are required to be replaced with 12" numbers if you change them. Most new numbers are applied in vinyl but you can have them painted if you so choose.
It won't affect the aircraft's value at all. The organization I work for change all of our N numbers when we get a new plane and it's never affected the values.
Blue skies!
http://www.dutchplanespotters.nl/main/photos/658/normal_D-FUKM.JPG
I know in Germany the first letter designates size (sort of, or number of engines, I forget exactly) so you are actually stuck with the first letter. Two jump planes I know of are a Cessna Caravan D-FEAR and a twin otter D-IVER.
Several years ago the FAA decreed that all new N-numbers had to contain all 5 characters to conform to international treaties. I've heard they've relaxed this so that shorter N-numbers are available again but haven't seen documentation of that.
