Cherokee 6 gross takeoff technique?
                    I had a near tree encouter during takeoff at near gross on my Cherokee 6, 1970, PA32-260, and wanted to get some comments.
I took off a week ago from a 4000 foot strip with my whole family aboard, and barely cleared the trees. Was doing the numbers, 10 degrees flaps, rotate at 70, climb out at 95, and still got this. Field is at 1000 feet elevation, 60 degree temp. Had a stiff 80 degree crosswind however (15 knots).
On the way back, different field, same conditions, 3500 foot strip. Did a little better, no comments from the passengers about how close the trees where, but I let it run-up longer before letting go of the brakes, and held it down/advanced the numbers by 10mph before rotating/climbing.
I'm seeing full rich/full power fuel flow in the 26-28 gallon/hour range. At full power climb, the fuel pressure is going a bit below 1psi... still in green, but made me nervous. Electric pump seems to work and that was with it on. I had the RPM checked today at full throttle/full prop, and it was showing 2700rpm. 1500smoh and all compressions in the upper 70's, as of last annual 8 months ago.
And the other odd thing, is it had a respectable climb (500 feet minute) once I got up 500 feet or so. It was just near the ground the thing was dogging out.
Have all the knots2U mods (root, flap gap, hinge) and the Laminer Flow wing smoothing.
Assuming I don't have a mechnical issue, I'd like to see comments about taking one of these off at near gross. Ground run, and if the rotation/Vx/Vy speeds need to be at book or a little advanced.
Some (including me) do the full power, then release brakes, then at rotation speed add the flaps. (One advantage of manual flaps.)
But thanks for the thoughts, I'll have to sandbag the aircraft to gross and see if indeed I can climb faster/at a steeper angle.
Oh, what is your fuel flow at full throttle?
I fly mine at gross regularly as my family and full fuel only leaves me with 150# for luggage. I have three teenage girls and I have to weigh their bags before each trip or they will take their whole bathroom.
What is better than seat belts is to ask several student pilots if they want to see a real plane in action. They make great ballast.
Frank.
I let the engine and turbo spool up with the brakes on, then accelerate, no flaps, to 65 knots. Backpressure on the yoke, pull 2 notches of flaps and it lifts of within 3/4 of the runway. It took some guts to try it the first time, but works fine also with 15 knots crosswind.
" Iregularly take off from a 600 meter runway in France at 1000 ft elevation at 30C at full gross with my T-tail turbo lance."
600 meter = 1 968.5 feet
30 degree Celsius = 86 degree Fahrenheit
I don't have the POH for my straight-tail Lance, but the ground roll in the books is about 1/4 lower for it when compared to the later t-tail.
Back to the original question. Yes, think of 4000' with trees as a 2-notch takeoff. You don't really need full short-field methods, but the 1-notch of flaps normal takeoff may not cut it at full gross. (As you have seen.)
Just a reminder though, this is a 260HP PA32-260.
Thanks for the thoughts. I'll give some of them a try.
Tell you what, the 6 at full gross seems better then a 172 with me and my instructor in it, as far as climb/runway clearance.
You will want an instructor and some altitude the first time you do a power-on, full-gross stall. It's not a bad stall, but it is different enough. Of course, the low-gross, power-on stall can really get the nose up.
With my straight tail Lance, I prefer to hold it on the runway until at least 80-90 if I have the runway. Then I get a good possitive rate right from the get-go so I can raise the gear at 20 feet without worry about settling. You might want to experiment with different rotation speeds for different runways.
The technique is described in detail on the AMRD website, photo's included.
Jim C is far more familiar than I am with this, maybe he could weigh in.
Did you ever get those VGs that you inquired about a few months ago? They should make a difference also to you, especially at gross.
