LED Light
How hard is it to install a LED Landing light on a 1976 piper cherokee 150?
  • I have a 73 arrow and it was pretty simple. There is one screw that holds the retaining ring in place. The light bulb then has two screw terminals on the back. Some LED bulbs are marked + and -. should not take more than 20 or 30 minutes.
  • Thanks so very much. Another question. Is it ok to use a heated oil stick to help warm up the engine?
  • Hi and thanks for writing. This is an amazing question that I've wondered for years. I'll pass this on to our A&P, Erich Rempert and get his answer for you. Please stand by.
  • Here's an answer from our A&P, Erich Rempert:
    Sure, I don't know how effective it will be, and it will only really heat the oil in the sump, but that's better than not at all. I'd just keep up with oil changes and make sure he looks at the oil as he uses the heater to make sure nothing goofy is happening. I see nothing wrong with it though.
    ~Erich
