Absolutely. Appareo has been really cool too. I bought it in June to also get the free usb charger. Of course, last week they released the Stratus 3. They are installing the2i in my plane now and they will mail me the 3i to swap out when they get them in a few weeks.
Coming along nice. I decided to leave it at this shop for annual and come back in two weeks. One thing that should be mentioned is that a newer encoder might be required for your install.
Any Ideas on how to install a Garmin GDL-82 in a PA-28 151? I am having issues with placement of the GDL box because my Transponder antenna is under the front belly. Not enough room under the panel to place the box. It is not a simple installation on a PA-28 Not as simple as Garmin made it sound and it looks like you will need an avionics shop to do the install not an A&P mechanic
Post some photos when completed. I considered the Stratus set-up, decided on Garmin GDL-82 in the end.
Good start! Post a finished pic, too
Paul
1963 Cherokee 180 B.
I had the usb charger installed in my Archer II. Provides a lot of IPad charging power.
2.1 amps per usb socket, if memory serves. Nicely done!
Just looked it up...2.5 amps per...
2.5, thanks for the correction
I wanted to refresh my own memory! I know the Sporty’s shop staff hightly recommended!
Paul
Paul
Hmmm. I should know this. It's kinda like a trick question on a test. ADF?
That's what my mechanic said.
Paul
Lucky guess Have a great weekend!
To clarify, my mechanic said the same thing about how it felt like his practical test. None of us knew what the antenna was.
Paul
Paul
Thanks for your comments, you beat me to it! (which is great).
Paul
Thanks for posting Looking great! Have you flown her yet with "In" working?
Paul
