Adding a step
My Cherokee does not have a step. Has anyone ever added one to a plane that did not have one originally?
Paul
1963 Cherokee 180 B.
  • Years ago, Piper offered a kit, part number 756-785, but the kit did not include the step, part number 65784-00.
  • Thanks. I’ll look around. It probably won’t be worth the cost.
    Paul
  • Paul,
    Is the step attachment plate on your plane? Behind the flap should be a reinforced plate with bolt holes in it. If it's there, you can mount a step procured from a boneyard. Take a look.
  • I don’t think so. It would be on the side and not the bottom, correct?
    Paul
  • No, it's not there. See if it's on your type certificate. If not, you can't install one without the help of a DER and a wheelbarrow full of money. If it is there, you might be able to get your mechanic to install one from a boneyard.
  • Where on the type certificate does it mention the step?
    Paul
  • Hi Paul,
    Good question. Okay, is it in the parts manual? That should be easier
  • Speaking of that step, has anyone ever stepped down from the wing and missed it, but not completely and caught the outside of your ankle on that piece of steel. :#
  • Oh yes, almost broke my leg and did a number on my shin. Not good, lol.
  • I’ve had a shin shaver episode on other cherokees before.
    Paul
