Correct pitot heat temperature
A member just called in with a question that I'd never had before so I thought I'd post it.
Question: "How warm is a pitot heater supposed to get?"
Answer : In the air about 25 degrees Celsius (around 75 to 80 degree Fahrenheit). On the ground, a couple of hundred degrees so don't grab it with your hand to see how hot it is!
  • Too late, did that about 40 years ago, but only once.
  • You're not alone. I think most of us have. I'm definitely in the "yes" camp, too. :)
  • I use the burnt flesh method also.
    Austin
  • I can commit crimes without leaving fingerprints now.
    Paul
    1963 Cherokee 180 B.
  • Too funny, Paul. I take it your fingerprints are permanently attached to some pitot mast somewhere, lol. :)
