looking for pictures of a fuel flow transducer installed in a Arrow
I'm trying to get an idea of how to install the fuel flow transducer in my 1976 200HP Arrow and would really appreciate if anyone had a photo or 2 or the plumbing I'd really appreciate it.
My engine driven pump outlet is only a few inches from the fuel servo inlet and the fuel hose now is about 6-8 inches and in a U shape.
JPI said to use about 2 feet and make a loop.
Just curious how other people installed it.
Thanks.
Thanks.
Someone got a picture for him?
Since JPI told me that since the distance between the engine fuel pump and fuel servo is only inches apart that I should make a loop with roughly 2 feet of fuel line.
Can you please look at this link and give me your opinion which line I should get to make a even loop, I was thinking Style D with 45deg ends, hose style 303-0 since my hoses are orange (I guess it doesn't matter since I'll use the orange fire sleeve) and size -4 since I'd be using 1/4 fittings.
Also, the fitting on the fuel servo is I believe a 45deg. If it were straight it would hit the throttle arm or whatever it is. And can't I just use the old fittings, I can't see a fitting with a bend it it from the spruce page you gave me.
http://www.aircraftspruce.com/catalog/pdf/hoseAssemblyform.pdf
Actually I think I'll just get the Style A with straight end to end fittings. Spruce said the hose with 45deg ends is $157 for a foot and $95 for 1 straight and 1 45, and only $39 for both ends straight.
When routing new lines, it is generally not a good idea to have elbows on the lines themselves but to use a treaded elbow. If that is not an option, try like heck not to have an elbow on both ends of the line (style D,E,F) as it is VERY hard to clock them accurately and there is no adjusting after the line has been fabricated.
I prefer the 466 line as it is more flexible, has a smaller O.D. and the firesleeve is built in.
Dont forget when youre figuring all this out that the whole transducer will have to be covered in firesleeve.
PilotKris
From the fill out form I thought that the difference between the hose style numbers were only color.
In summary, I'll get 2 AN816 4-4 fittings, 2 1ft hoses style 466 A and I should be ok?
I'm glad I looked closely at the transducer, they sent me a 231 in the sealed box with the gauge and it was even labeled 201. Bit they hurried and already sent me a 201 transducer.
PLUS, they seem to answer the phone pretty quickly now.
Another question, do you know where to get a good price on a adapter cable to run the FS-450 to my Garmin 396 and still use my power plug.
I used to have a Zaon traffic alert unit and it came with a cig power plug that plugged into the Garmin and had a pigtail that connected to the Zaon to interface data to the GPS
Before you order the hoses, I'd mock up the installation with some old hose and plan out the routing and were the Adel clamps will be located (nylon tie-wraps should be avoided). It's best if there is one on each side of the transducer fairly close to it. Obviously you want to avoid the exhaust by a wide margin. Remember, the hose is measured from flange to flange.
PilotKris
And thanks Matt, was nice talking to you. If you can beat the show special I might do the exchange since I just had an unfriendly quick answer to my question from JPI
Now JPIs monitors might be able to piggy back on EIs transducers so if Matt can match JPIs price, you would able to use Matt's pretty red transducer. If EIs unit is STCd as a replacement for your mechanical, pressure type fuel flow gauge, that would be a very compelling reason to go EI as you could eliminate a pressurized fuel line in the cabin.
BTW, are you sure about the fuel line I.D.? Are you sure the lines aren't -6 (3/8" I.D.)? What size wrench do they take on the "nut"?
PilotKris
im not sure about the line size, i just assummed it was 1/4" id because the transducer is. Ill have to check that out.
Another question, how do you determine HP without RPM and MP sensors?
You've missed out on a huge (and I mean HUGE!) advantage of your FF as it can replace the pressure type FF of fuel injected motors. That is a MAJOR increase in safety as it eliminates the pressurized fuel line going from the spider valve to the FF gauge in the cockpit.
PilotKris
PilotKris
