430 found switched
                    I'm wondering if anyone has any experience with this. I recently  bought a '78 Lance with a Garmin 530 and 430, both showed in the logs upgraded to waas. The short of  it is in trying to update the nav cards, I discovered the 430 is not waas, and have since discovered it's not even the same unit as the one upgraded in the logs (different serial number). I went back to the company who sold the plane to me, and they seem to be headed for the position it must have been stolen (swapped out) at some point and there is no way to find out who or when. It wasn't just pulled out and another plugged in, the antennae for the 430 was also changed to a non waas antennae. So some work was done. This brings up all kinds of issues.... misrepresentation of the aircraft, a major alteration done with no record of it in the logs, no form 337, my panel doesn't match the serial number in the logs, etc... Am I just screwed on this? I don't think it's enough money to hire an attorney. Is there anyway to force their hand? Also, how to deal with the discrepancy in the logs now. Of course, everything works fine... it's not the end of the world to not have waas on the # 2 Garmin. Maybe I'm old school, but I feel something should be done here.
Mark
I think you can safely eliminate avionics theft here. While It is not uncommon to see thieves stealing a radio and replacing it with a lesser one, it would be a first for them to take the time and the risk of "replacing" the GPS antenna. They do this because the customer doesn't know they have been ripped off and the theft (and the serial number) is never reported or reported long after the theft occurs. Something else is at play here? Looks like you bought the aircraft through a broker ( not from the actual owner) or the aircraft was owned by a company. Either way, the broker or company that sold the aircraft to you has a reputation to "uphold". I would try to get to the "real" owner of the aircraft at the time of sale or the avionics shop that installed the 430 originally and see what they might know about the aircraft and then perhaps, go back to the company that sold you the aircraft. Forget lawyers. If you can figure out what happened, you may be able to put pressure on the seller to "help" make things right. Your loss is about $4000. That's the cost to upgrade the 430 to WAAS plus antenna installation. Personally, I wouldn't let it go! Remember, the pen is mightier than the sword! Another important "point" here! next to the engine, the avionics represents the largest share of the value of the aircraft. We pay someone to do a pre-buy of the airframe and the engine. We "assume" that the avionics are okay and "legal"? A pre-buy of the avionics also makes a whole lot of sense on any "significant" aircraft purchase. Bob Hart www.AvionixHelp.com
Start using the pen and post the sellers' name or broker and inform them of this. If their names start popping up from unsatisfied customer feeds it just may prompt them into helping you.
Keep us posted on how it turns out.
LJG
Sorry about the outcome. Maybe it's time for an "article" on the importance of "the avionics" in an aircraft purchase? Can I use your story as a basis?
Thanks! Bob Hart www.AvionixHelp.com
I'll let you know before I do anything. Bob Hart www.AvionixHelp.com
