PA28-140 (150 hp) what are the procedures: slow flight and stalls
Getting ready to do my flight review (PA28-140 (150hp), I want to make sure the procedures are same as others use, see below, provide comments and changes if necessary to what I have stated. The use of fuel pump on and carb heat (I typically will just put fuel pump on and leave carb heat off). I fly in Colorado Springs so, unless absolutely necessary, I will not turn carb heat on, lose some of the power which is not desirable.
Departure stall
Fuel pump on/carb heat on???
Clearing turns
Power to 2000
At t/o speed (depending on whether aircraft uses MPH or its)
Full power
Control, gently pull back (lots of right rudder)
Stall
Recovery (lower nose...gain speed, gently pull up)
Fuel pump off/carb heat off???
Approach to landing stall
Clearing turns
Power to 2000
Once in white arc, start adding flaps (eventually full flaps)
At landing speed (depending on whether aircraft uses MPH or its); throttle idle
Control gentle pull back (right rudder)
Stall
Recovery (lower nose...gain speed simultaneously full power, gently pull up, start getting rid of flaps)
MCA
Clearing turns
Power to 2000
Maintain altitude (nose=speed and throttle=maintain altitude)
Departure stall
Clearing turns
Power to 2000
Full power
Stall
Clearing turns
Power to 2000
Stall
MCA
Clearing turns
Power to 2000
