Flight to Canada
A couple of questions regarding flight to Canada. First will I need a 406 ELT? Second do I need large registration numbers?
  • No, you don't need a 406 ELT, a 121.5 ELT is still fine.
    As to the question of small numbers, I don't know, but I copied this from the COPA/AOPA handbook on Canada/US Cross border operations. A quick glance didn't mention number size.
    Aircraft and Pilot Documentation
    Visiting pilots are required to have the following documents in their possession. All documents must be current and original; photocopies are not acceptable.
    Aircraft Documentation
    -Aircraft registration certificate (temporary ¡§pink slip¡¨ registration forms are not valid for international flights as described in US Title 19 Customs Duties, Chapter 1, Part 122, Subpart C Section 122.27)
    -Aircraft airworthiness certificate (for aircraft with a C of A or Special C of A);
    -Aircraft operating limitations (including the ¡§Standardized Validation of a Special Airworthiness Certificate ¡V Experimental, for the Purpose of Operating a United States-Registered Amateur-Built Aircraft in Canadian Airspace¡¨);
    -Weight and balance information;
    -FAA 337 form when the aircraft has been fitted with extra fuel tanks in the baggage or passenger compartments.
    > fine.
    > acceptable.
    > Section 122.27)
    > compartments.
    I have heard otherwise about needing a 406 ELT. Please explain your source.
  • No, you don't have to repaint your aircraft to bring it on a trip to Canada.
  • > I have heard otherwise about needing a 406 ELT.
    As of a week ago:
    http://www.aopa.org/advocacy/articles/2009/090507elt.html
  • Same information from COPA, you can follow the link and scroll down
    for the story.
    As well, they co-produced, with AOPA, a document on cross border flying that you can access as well, just hit the "Flying in Canada" button.
  • While passing through the ADIZ ( Air Defense Identification Zone ) your numbers must be at least 12 inches high...
    You can put temporary stick on numbers on the airplane.
  • There is no ADIZ between the lower 48 states and Canada. The contiguous ADIZ follows the east coast, passes between Mexico and the USA, and goes up the west coast.
