1976 Arrow II bottom engine cowl, what size bolts are on the front bottom
                    I took my cowl off a few weeks ago to fix the alternator wire. I was cleaning the belly today and noticed the front 2 bolts are missing on the lower engine cowl.
There were no bolts in my cup when I was finished re-installing the cowl so I don't know what happened to them.
Does anyone know the dia and length. It looks like a 8-10mm hole
Also, the rear bolts push all the way through and you put a nut on them.
It looks like the front ones just screw into the engine mount piece. Is this correct?
