Recommendations for Cleaning and Waxing my Plane
Hello All,
I am completing the annual and want to do more than just wash the plane. I want it to sparkle and look slick. What are my next steps to removing oxydation and protection and shine? What do you recommend and why? I've heard that some silicons leach into the aluminum and others just aren't worth the effort.
I've washed it many times, but haven't polished or waxed it for at least 2 1/2 years - granted, I was deployed a lot during that time and she was hangared.
The white (Matterhorn White) is oxydizing while the metalic green looks fine. I cleaned the bottom with both Avgas and then Spartan MD-20. WOW! didn't look so bad, but a lot of work, especially around the antennae.
I am not adverse to work, but I want to do it right and get the most out of my efforts to protect and show off my plane.
Thank you,
Martin
Thank you,
Martin
Not heard of it.
Top Coat F-11. I have been using it on the cars and my plane, even the windscreens. My plane looked like it was freshly painted when I bought it but the F-11 makes it sparkle, also seems to make getting the bugs off easier too.
Be careful setting things on the wings though because they will slide off way too easily!
Thanks Ray, I have to look into it.
Interesting stuff here. I have a 180 that was painted in 96, (Jet-Glo) and has been hangared every since. Before we bought the aircraft, I believe someone either clay bared it, or applied ceramic type of coating to the paint. Not sure the after affects, but it literally looks so dull, one would think that its been outside for 30 years. I recently tried Flitz wax/polish with a wool buffing pad, and it is starting to shine in the areas I have polished. A lot of work, but the results are great. Nothing else has worked on it. Even tried the Wash wax stuff, Etc. Whatever is on there, is harder than woodpecker lips...
Watch out for that little stubby transponder antenna on the forward bottom fuse when your waxing. It is easy to break and a real pain to replace.
Austin
Hi Austin, and don't forget to say it's a "real pain" with amplification! Been there! Scrapes all over my wrists to prove it.
I have a 1980 Archer II. It was painted in 96 and hangared, the paint looked great but I could see that it had some haze and oxidation. First I used a Griot's Garage orbital polisher with polishing compound. It made it better but did not cut through the haze completely. I asked an individual that reconditions planes for guidance. He said the orbital polisher does not cut as much as a regular circular polisher. He said you need to be extra careful on the rivets etc.
I did that and it did a great job. After compounding I used Rejex to seal it. Rejex is available at Spruce.
I have had many compliments on the shine. People can't believe the paint is that old. The bugs clean off easily.
You will find a small 1" paint brush cut half off or a tooth brush will be helpful around rivets. I have just used auto Turtle wax and hand waxed it. A lot of ugly work for sure.
Austin
I always bring a friend when I'm cleaning my plane. His name is Jack
Jack Daniels.
Check out a product by Malco Chemical called Rejuvenator. It works wonders on dull and oxidized surfaces.
I know Jack...he’s a friend of Johnny Walker![:D :D](https://piperowner.org/talk/resources/emoji/lol.png)
Ha! Too funny.
"I get a little help from my friends!"
I use Blackfire products and found it better than anything else I've used. Jack helps me as well.
Jack creeps up in the most unlikely places, doesn't he? I'll look into blackfire products. Where do you get them?
