Constant speed prop stc for cherokee 140?
Does anyone know if you can put a constant speed prop on a cherokee 140 with a 0-320 160hp? Any STC info or numbers to call? Thanks
  • If there was one, it would be a big job as your accessory case most likely does not have the provision for a governor. So, you would need a new cover, the gear driven by the crank gear, and would have to drill and tap your case to provide the entrance of the governor pressure to the prop. I think it would be cheaper to go buy an Arrow or something with it already.
