Gascolator sump valve failure on takeoff
During takeoff, the sump valve for the gascolator on my Arrow failed! This caused a loss of fuel pressure, and subsequent engine failure. Lucky for me i had only just begun to rotate, and had plenty of runway left. I found the sump plug in the run-up area. Upon further inspection, the retaining ring that holds the sump plug in had failed, and was inside the coupling between the gascolator and the sump valve. Just wondering if anyone has seen this happen before, as it is obviously a very serious and potentially fatal issue! Thanks!
