Considering an 81 Archer in CA and need Advice
I'm looking at a 81 Archer in S. CA and had a couple questions after I went to look at it this weekend. I noticed on the cowling right above the aft attach point the cowling is bowed on both sides. The bow is about 4 inches long and sticking out about a 1/4" out - has anyone seen this before? Also, in the rear of the aircraft, on the top above the fan blower motor there is a lot of white specs/dust covering the aluminum. I grabbed a mechanic that was in a shop next door and he indicated that this is normal S. CA oxidation 'crud'. I have owned a couple Arrow's but have never seen this white 'crud' before on the aluminum surface so was curious if this is typical in S. CA?
Randy
