Nose bushing installation question
I have a 75 Archer that just started to shimmy. After looking at the post here I am going to replace the bolts and bushing in the nose wheel link. My question is how do I get the old ones out and the new ones pressed back in? Would I need special tools or a press to do the job. My hope is that I could pull them out by hand or maybe with a small punch to drive them out.
Bill B.
Bill B.
Good luck,
>MikeL<
'65 180C
>MikeL<
I made two landings and did not have a hint of shimmy! I am still confused by the bushing thing though. I looked at mine and another archer in the hanger and both have their bushings welded in the sissors link. How would you replace just the bushings? Maybe I misundestand where the bushings go. I though that they go in the sissors link.
I don't need them now but my in the future so I would like to understand this.
Thanks,
Bill
BTW: The bolts should not be used with nylon insert type nuts. They should have cotter pins in castle nuts. If yours was hand tight, that is scary... real scary. If the bolts came out... the second you lifted off your nose strut would eject leaving you with no tire and a real problem! The only thing holding the oleo strut in once you lift the weight off is the scissor. Same with the mains... Also, do not ever take off a scissor if the plane is jacked up off the ground. They are under very high pressure and will eject spraying 5606 fluid like an explosion. It is best and safest to release all pressure in the strut before ever taking off a scissor, however, it can be safe as long as the weight of the plane is on it if you know what you are doing...
To make the bushings last longer, whoever is doing your annuals should be lubricating the bushings. If you look at the part where the long bolts go through (top and bottom) you will see a small hole in the very center. You take aerosol lube such as LPS 2 (with the red spray tube) and put the red spray tube in the hole (it fits perfectly). Shoot it in until it oozes out both sides of the bushings. All good.
