PA28 Heater Controls: What are these things?
;I have a PA28 Archer that has a lever with a knob on the end located on the metal down by your feet each side of the tunnel that goes from the front to the rear. The POH and the parts book say they are heater controls. Mine will pull to the rear and I can feel a spring pulling them back forward. They don't seem to do anything. The heater airflow doesn't change. I don't feel anything being moved. I do know that the metal around the knob get so hot it wll burn you. It would seem that the metal is suppose to duct air to the rear but I don't feel any hot air going to the rear as my rear seat passengers will tell me.
What are these levers suppose to do?
Thanks,
Bill
Thanks,
Bill
I have turned on the heater controls by the copilot seat but nothing happens when I pull these levers. I suspect they are supposed to control some damper to redirect air but they don't seem to do anything. When I pull them I feel the spring pressure and when I let the lever go the spring pulls it back forwared but I don't hear anything moving. There doesn't seem to be a locking position for the lever either. Maybe in the past something was disconnected before I purchased it. I just don't know what it is supposed to control.
If I can figure out what it should control then I can find the disconnect.
Thanks,
Bill
The knob/lever that I am talking about is item 2 on the attached page from the Piper parts manual. I can pull it to the rear of the plane when the heater is on but no air flow seems to change. A spring pulls it forward when I let go. I don't see anyway to lock it aft. Basically it doesn't do anything.
Thanks,
Bill
Eric
The heat lever control a damper that is mounted to the firewall. This damper takes the ram air that is passing through your heat exchanger and either diverts it outside the airplane or channels it into the airplane. There is a damper assembly on each side of the firewall for the two heat ducts at the floor. They are individually adjustable for the amount of open or divert you want.I have the copilot side (wife's) set to open first and more because she is usually freezing where mine opens later. The heat exchanger puts out some really hot air so be careful with it.
I forget exactly how the defrost damper works I just know the tubing is much smaller and there are two of them.
If you are not getting heat your damper could be jammed or the cable may not be functioning correctly. It is also possible that the hose or hoses might be disconnected.
Good Luck and have fun.
I will take the ductwork apart and see whats going on with them. I have plenty of heat from behind the dash so that part is working and the metal around the levers is very hot. The damper or blade or what ever closes off the heat at your feet must be disconnected.
Thanks all!
TMeyers has pretty well stated the answer. There should be no springs on those levers, and you should feel a GREAT amount of heat on the top of the aluminum channels. A properly functioning heating system on a -181 or even the Hershey Bar Archer will cook you right out of the plane, even in the coldest weather. Here's a page from the -181 manual illustrating the heating system. The key to a properly functioning system is the heat diverter box at the center bottom of the firewall. Make sure the cable from the HEAT lever is moving the flapper assembly to the fully closed position, when in the OFF position. Then make sure the flapper opens smoothly to allow heat from the muffler shroud to pass through to the center duct. Also, check the flapper for a good seal to the box, that is no warping.
The small black levers on the center channel move forward to divert heat to the front seat, and rearward to divert heat to the rear. I usually leave mine in the REAR position all the time. You'll melt your sneakers if you use the FRONT position.
Keep us posted on your results.
VFRs, without TFRs,
Dennis-ARR
One thing to caution you about. The aluminum is very thin and you need to be careful about trying to turn any screws or nuts as the levers and arms will bend very quickly.
Then in the rear where the air should have came out was blocked by excess carpet that kept air from flowing out. I cut out all the carpet that was affecting the system and got the damper doors working and the trimmed out the excess in the rear. I have not flown it yet but I am sure that it is fixed.
It was not a lot of work but there are a lot of screws to remove so if you go into this make sure that you have an electric screw driver.
By the way, It was a great time to try a unique fix for the chipped up flap handle. Someone on this forum suggested that a 1" piece of heat shrink makes a good fix for it. I finally found the 1" heart shrink, took the rubber handle off and put a cut to length size piece on and heated it. Worked great. Its a little dull but looks better that the old chipped up handle.
