Archer II Door Handle
Does anyone know if there is an aftermarket additional door handle to be installed in the door of an Archer II to help pull it closed before latching? I find it difficult to pull the door closed enough to allow latching at the top.
I sounds like your door needs to be adjusted. I suspect your Archer II is identical to my Warrior II, in the door operation. You should be able to gently pull the door closed with the armrest, and it will catch at the latch along the rear edge of the door. Then, move the latching handle down to fully latch the door. This motion will bring the engagement tang in range at the top of the door. Finally, rotate the top latch. It should be so easy that you can easily do it, in flight, from the pilot's seat, should you take off and find you've forgotten to fully latch the door on that HOT Summer day.
VFRs, without TFRs,
Dennis-ARR
The top latch is fully adjustable. Look at page 2K24 in the Service Manual. It is a simple procedure.
Usually the latch gets out of whack when someone slams the door while the top latch is in the engaged position.
VFRs, without TFRs,
Dennis
Well - if you are asking, how about a PT-6 with STC paperwork and a pre-paid fuel card for my Cherokee 6?!!!
(You did ask...)
