PA32R-300 Lance Left Seat Repair
I recently acquired a 1977 Lance and have found that the position stops and lever mechanism on the left seat are severely worn and are in need of either repair or replacement. I have been unsuccessful finding replacement parts and am assuming that I will have to have the parts machined. Any help would be greatly appreciated as this is my first plane and have much to learn.
Can you post a photo of which bit is bad?
As this is your first aircraft you are feeling your way, - the A&P will help you through it.
The IA will take a very dim view to any illegal mods, not half as much as the FAA though.
In this case your best bet would be to discuss it with the A&P... he would have seen it all before and have a fair idea of what you are up for.
Most maintenance has to be recorded and certified. That includes Pilot/Owner maintenance but you will also need to be familiar with the task and limitations before you embark on any of that.
Many IA's will refuse to touch an aircraft that has been dicked about with by the owner, either that or run up a horrendous bill trying to sort the mess out.
Find a good A&P that is recommended by operators of similar types, work in with him and you will find the cost of ownership becomes very reasonable.
