Need to Haul about 850lbs - 3 adults and 3 children about 400-500 NM's
Hi Everyone:
I'm deciding on which plane to buy with a specific max mission. I have three children, one of whom is disabled and has a nurse, as well as a collapsable wheelchair. That's 6 with my wife. I'm looking to haul everyone plus luggage, and calc comes out to just under 850lbs. I'm looking for a 3 hour range with reserves, since having kids will probably limit them to that amount of time without a rest stop anyway. Mostly paved runways although perhaps a couple of gravel and really well groomed grass. Some altitude as well in the Northeast (Vermont). Without going turboprop, it looks like the choice is rather limited to the big 6, or 6X, 6XT, Cessna 206, although I have a friend with a Turbo Normalized Bonanza G36 and he swears by the increase to 4000lbs gross which he says gives him just under 1300 usable (not sure I believe it). I've thought of others (dehaviland DHC2) or something to that effect. Essentially I need a big hauler that will fulfill the mission, and is hopefully not a complete bore when I'm flying by myself. Thanks everyone.
See this attached pdf for specs on all the different PA32 models. You'll see that the standard empty weight goes up with time. Some of that is just the factory getting more realistic. But the early models generally came with fewer options and will hold more as a result. You still have to check the actual empty weight on each airframe you look at, though. Note, also, that these planes can carry a *lot* of gas. You can leave 30 gallons behind (200 pounds) and still fly a comfortable 3-hour flight with reserves.
If you continue to look at turbos, in the pre-1994 airframes you really want one with the intercooler mod. Those engines run hot without the intercooler. Piper revamped the cowling in 94 and fixed the airflow, so the later ones are OK without intercoolers.
IMO the "sweet spot" in the line is the straight-tail Lance. It carries just as much as my fixed-gear Toga but goes faster because it can pick up its feet.
