constant speed prop question
My owners manual for my 1978 Cherokee 6-300 has 4 different rpm and manifold pressure settings for a given alt. an example is that to get 65% power at 3000 I can run 2100 rpm and 24.8 man. Or 2400 rpm and 22.5, or 23 squared. Why would I chose one over the other? Running at 2100 produces a quieter cabin so why is that not the way to go?
Nick
Nick
You can pick any of the combinations that the POH gives you for a given power level. Or you can interpolate and pick something in between. Whatever floats your boat is just fine with Piper and Lycoming as long as it's within the ranges published in the POH.
This is a memory aid which is a happy coincidence of our engines and our units of measurement. It's close, but not actually true, for most horizontally opposed normally aspirated GA engines. It's completely off base for turbos, radials, geared engines (e.g.: Rotax), and anything that uses the metric system. You want to learn what the POH limits are and stay within them. If this "don't go over square" rule of thumb keeps you inside the POH, fine. But realize it's only a rule of thumb for the kind of plane you're flying now and don't get married to it.
Your last two sentences are true for cruise. Your first sentence is not necessarily consistent with the last two, however.
