Partial Engine loss on Climb-out in Piper Arrow
Tried to Google this several different ways and have had no luck with a solid explanation.
Scenario: Hot July day, High Density Altitude, Full Fuel, Single Pilot, Piper Arrow II.
Just arriving at an airport on this hot July day to drop off a friend to pick his plane up from maintenance. The Arrow had sat on the ramp for about a half an hour, most likely heat soaking in the 98 degree humid day. Ready to take off again, Called Ground, taxied to the run-up area, normal run-up, called tower, and cleared to go. Here is where it happened. Rolling out and rotated fine, broke ground and started climbing Vx. After about 200 feet AGL, Rough Engine, Partial Power loss, shaking airframe... Calling the tower to explain, and let them know it will either be off field on a close by highway or back to the airport. Clearance either way! First thing was to keep airspeed going. Trying to hold best glide with a shaking airframe and partial power (almost like it was running on 2 cyls or less). Leaned out the mixture in case in was fowled plugs (which is what it felt like). Thinking back, that was probably a bad idea. After a few minutes full power was restored and was able to gain some altitude. a couple minutes and a couple hundred feet more, happened again. At this point a turn back to the airport straight line was possible. With enough altitude and power to make it back, there was an uneventful landing on the opposite runway. Cleared the runway, Did a Run-up (NORMAL!!) Confused!?!?!
Things that where checked (by two maintenance shops):
all 8 plugs - almost flawless
compression check - high 70's across all cyls
Everything else looked mechanically sound
Aux Fuel pump WAS used (well still trying to remember!!) Common motion to roll up mixture before run-up and hit the fuel pump switch "On" at the same time.
Flew after this for a good 15 hours with no issues...
Looking to this forum to see if there had been any similar issues, or thoughts on Why!?!? With all tests coming back normal, its hard to grasp.
Talking it over with numerous pilots, mechanics, reading forums, there have been a couple of could be...
-Vapor Lock (Understand this issue fully on startup, but cant comprehend it after startup, taxi, run-up, take-off roll)
-Detonation (100LL fuel was being run, full rich on take-off, and it was off a 200ft AGL airport), Maybe?! Seems far fetched
Curious about the sticking valve, and spyder valve. With the loss of power, I can't imagine one sticky valve would cause that? Maybe more than on? What are the chances? For the spyder valve, I'm no 100% on how the mechanics work on that? Does it get out of sync like timing?!
Thanks for the replies!
I can't say for sure it wasn't a transient mechanical defect or bad fuel - but don't rule out the notion that it was just too hot.
