PA-32 6/260 unusuable fuel
Does anyone know what the unusable fuel for a '67 6/260?
I've looked all thru my flight manual, weight and balance, and POH and can't find anything.
Kurt Johnson
Kurt Johnson
Good question Kurt. Hopefully someone will weigh in on that.
This is what I found in a 1968 6/260 manual. Looks like it is only a pint a tank
![](https://piperowner.org/talk/uploads/editor/h6/bvsqpgif4aed.png)
http://www.mattbeyer.com/poh/PA-32-260-Cherokee6-POH.pdf
Thanks Eric!
I see it now. As I was glancing thru the material I was scanning for numbers. Thanks Eric
Kurt Johnson
Anytime Kurt, it is impressive there is so little unusable fuel. Would not want to test it in a slip!
For the Seneca III it is 2.5 gallons a side ~ 30 lbs of deadweight but I like to land with at least 10 gallons a side anyway. In the Seneca III there is a note about unusable at critical flight attitudes and I assume they are referring to coordinated flight at landing and takeoff pitches.
