Seat roller maintenance
I'm finishing up my interior and about to put the rollers back on the seat. I was going to clean everything real good and then lube the insert (bearing) that goes inside the rollers.
Should I use a light coating of grease or something else like TriFlow? Don't want to attract dirt with grease but since the insert is inside the roller I think it might be ok.
Any suggestions on how to lube the rollers?
  • Found an old article by Scott. I guess dry lube it is. No grease. Should of searched better before I posted.
  • McFarelane sells replacement rollers too. Mine were the wrong size on one of the seats and all better now. I think just about anything would work to lube the rollers.
    Congrats on the final stretch for your interior!
  • I used lithium grease on mine but hard to know the best lubricant.
  • My PA32 maintenance manual says every 100 hrs. to use AERO LUBRIPLATE, FISKE BROS REFINING CO, MIL-G-771 1
    Lon Stratton
    n7xa.com
  • Oddly enough, I have 2 different sizes on only the adjustable seat. Not sure if it is suppose to be that way or not.
  • It is correct if there is little play when you lift the seat front
    Mine were likely wrong for years (decades) until i researched and realized they had two different parts for the same years and either could be correct....
    If you need the smaller size I think I might have kept them. It is more likely you need the larger size as I don't think the smaller ones would work at all if your frame was designed for the larger. radial delta is 0.1 inches.
