Arrow Electric Trim Successful Repair
Recently, I was able to repair my electric trim servo and it is now up and running. According to records, the trim hadn't worked for years. The motor would turn but the solenoid would not engage the clutch.
Power to the terminal block was good so I cleaned the lugs and the connection point and now it is functioning normal. The clutch does slip a bit so my next step is to check on the clearance and make appropriate adjustment.
I wanted to put this out there for anyone having a similar problem. Easy fix.
Todd 1977 Piper Turbo Arrow III
Todd, thanks for sharing!
