Fuel Flow at Full Throttle
Does anyone have any Data with a Cherokee 180's fuel flow at full throttle (2700 rpm) running 100 degrees Rich of Peak (Best Power)?
I was running 17 gph during full throttle climb-out and was also interested in this value from other 180 drivers.
Thank you in advance.
60 lph is about 15 US gallons per hour
Doesn't the POH say something about the expected fuel flow in climb?
I believe you are quoting cruise fuel burn whereas I am quoting full power (full rich) climb, hence the disparity.
Cheers,
>MikeL<
'65 180C
Lycoming sez not to lean above 75% power. I would not run my engine at 2700 and 100° rich unless above 8500' and at that altitude mine will only turn 2650. I view 100° rich as sort of on the lean side for that kind of power setting.
>MikeL<
