Weights and balance
I bought a 1975 Cherokee 6/300. It has a modern panel and has had interior updated over the years. It has factory AC but hasn’t worked in some time and I have no near future plans to get it working. It also has wheel fairings. My useful load is 1273# with max load 3400#. My question is, are there things you can do to increase useful load 50-100# and shift the CG aft a little bit? I was thinking of having the compressor and/or condenser removed at my annual. Not sure how much things weigh but if I could remove weight from the front of the plane would make the balance a little better too. I attached a sample of what full fuel and 4 adults typically looks like. I have to add weight to the aft baggage compartment to stay in the envelope but then I push my weight up. It gets difficult to stay in the envelope if you have two people up front.
Thoughts?
Thoughts?
Hi, having owned 4 Seneca's over the years I always had ballast in the rear baggage compartment. I had 2 twenty-five pound dumbbells' back there to make it work. That's just the way PA-32's and 34's are. Also, regarding the air conditioning: It has tremendous value at trade in time. You may want to consider getting it repaired and enjoying it in the summer. At trade-in time it could be worth over $10,000. Regarding gross weight increases to have a useful load increase I'm not aware of anything out there.
Have you removed your vacuum system yet? On my Arrow it netted a 30 pound useful load increase.
