Turbo Arrow Electric Trim
Hello all,
I am in need of removing the servo from my 1977 Arrow. My question is regarding the cable. It being under tension, I'm not sure if I need to worry about it unraveling off parts such as the trim barrel located in the tail after I release the tension.
Any help is appreciated.
Thanks,
Todd
  • Update on the Trim. The servo was removed and repaired successfully. I used a soft wood clamp to avoid the cables from unraveling on the barrel located at the stabilator.
    The servo was reinstalled and the trim is now functioning. The repair was simply cleaning the terminal block for a clean connection.
    Thanks,
    Todd 1977 Turbo Arrow III
  • Great to hear it's repaired! Thanks for posting!
