Cruise leaning
For those that have an engine monitor, where do you like to run your engine at cruise. I'm operating an O-360. Lycoming manual says best economy is peak EGT and best power is about 175 ROP. I tend to run about 65-70% power and at peak EGT. That results in about 8.5 gph. I'm usually not in a big hurry.
  • Hi N56404,
    I too run 65-70% and peak EGT in the leanest cylinder. However many times I also lean by ear and feel. Honestly, in my O-360-A4A at altitudes below 4000 feet, I do not see that much difference in economy.
    For best economy, Lycoming notes:
    "Slowly lean the mixture until engine operation becomes rough or until engine power rapidly diminishes as noted by an undesirable decrease in airspeed. When either condition occurs, enrich the mixture sufficiently to obtain an evenly firing engine or to regain most of the lost airspeed or engine RPM. Some engine power and airspeed must be sacrificed to gain a best economy mixture setting. ​NOTE: When leaned, engine roughness is caused by misfiring due to a lean fuel/air mixture which will not support combustion. Roughness is eliminated by enriching slightly until the engine is smooth.​"
    • Michael Jay Jones (MikeJJ)
  • I will run my O-320 at about 70-75% and will lean the mixture until I notice the RPM going up. Once it gets to its 'peak' I'll leave it there and that seems to get me the best cruise mixture setting. I do it in the O-360 powered plane at the flight school I maintain, and it yields similar results. No need to over complicate these simple engines.
    Hope this helps.
    Kyle LaMontagne
    AP/IA, PPL
    1974 PA-28-140
    N41383
  • I agree. Your process would lead me to believe you operate at "best power". If you did monitor EGT via an engine monitor, I bet it would be right at the book value of about 175 ROP.
  • Use the Lean Assist on the 275 to ROP. Running about 9GPH at 75% power, but to be honest still dialing those numbers in. Right now longest flight is just over an hour to the farms from home plate and training time with the CFI for insurance before I can take the fam for $200 ice cream and thrown rolls.
