Mixture control support bracket mounting location.
Hello, I am looking for picture of the correct mounting position for the mixture control cable support bracket part #63964-00. The plane is a 1966 cherokee 180 serial #28-3757
Hi STEVEL,
I have a 1966 Cherokee 180 and when I get out to the hangar tomorrow, I will see if I can get a photo for you of the position on my aircraft without pulling the bottom cowl.
Hi STEVEL,
I took some photos of the carb and throttle cable support bracket just removing the top cowl. I hope this helps:
