Piper 28 Series door seals
Aircraft Spruce sells door seals for the PA28 that attach either to the fuselage, or a special order unit that attaches to the door, as it came originally from the factory. The latter is more expensive. Does anybody know if they are equally effective in controlling water leaks around the door? Thank you for the input.
Dave at Blue Flight
Dave at Blue Flight
I am new to this plane (Piper Archer) but was told that I needed to get the leaks under control because of the impact on the avionics. From what you said, it seems that it is just something to tolerate? True?
Blue Flight
Blue Flight
I also found that the window seals have a gap at the bottom. That needs to be sealed up or the whole seal replaced. I then found that there was a leak at the bottom of the windshield. I took the retainer strip off and sealed around the bottom of the windshield and put the retainer strip back on while the sealant was still wet.
I now only get a little leakage when it rains heavy.
The door hinges and seals are next.
Good luck.
Steve
I have used the http://www.aircraftdoorseals.com/index.php?cPath=21_26 - and the ones that attached to the door frame. Like other people have mentioned, these get kicked/scuffed when entering or egressing the plane. I spoke to Aircraft Door Seals when I was at 2010 Oshkosh, and they admitted that their newer variant which attaches to the door frame is better. Unfortunately, I had already installed some generic door seal from Aircraft Spruce by then.
Another thought - if your plane is living outside, is to use a plane cover (Bruce's Custom Covers are great quality) then consider putting a piece of plastic to cover the door area underneath the cover. It's a bit of pain to do - but if you are leaving the plane outside, it may prevent the Cherokee flooding!
PETE OTT
PANAMERICAN LOGISTICS
Larry
