PA32 Main Fixed gear Schrader Valve seal
I am wondering what you guys know as I have a 1969 PA32 300 and had to replace the seals on the Schrader valve Assy's for the main gear. The parts manual calls for a 5/8 " aluminum crush washer but there was an o ring installed and the top of the gear casing has a concave groove where the Shrader Valve Assy seal s installed. The O ring is clearly required and works fine but the parts manual says something else. Anyone else with this system or do I have a different gear that was installed on the aircraft?? Thanks in advance!!
Tim
Tim
