Yoke Electric Trim Switch
Looking for acceptable replacement. Salvaged part is pricing out at over $850. Any suggestions? I am shocked such a common part is not so commonly found. 79652-03
  • All switches are overpriced in the Piper world. I'm trying to find a better deal. stand by.
  • I haven't found anything yet but I have an idea. I want you to contact two companies that might have them unadvertised. Mayday Avionics in Michigan https://www.maydayavionics.com/ and Autopilots Central in Oklahoma https://www.autopilotcentral.com/
  • I got one fabricated
  • That is an outrageous price!! It's worth about $20.
    Austin
  • Roger that, Austin.
  • Appreciate the advice. I’ll check with the companies listed and circle back with you guys.
  • Have a look at this link. I've been using this for the past 8 years. It is of excellent quality and has been totally reliable. It is a momentary rocker, rather than a slide switch but in use works much the same.
    Cost from Digikey.com is about $12.00 plus shipping. It isn't a direct replacement so I had to make a new plate for the yoke to install it.
    https://www.digikey.com/products/en?keywords=CKN2040-ND
    At this price you can afford to buy it and see for yourself.
  • Unfortunately it isn't legal, so you're on your own with this solution.
  • I was having problems with mine also. My avionics guy was able to disassemble the switch, clean the contacts and reassemble it yesterday. He says it's working like new... can't wait to try it as it has not worked but maybe twice since I bought the airplane.
    He also noticed someone had replaced the phenolic sleeve/yoke stop incorrectly so when the yoke was pulled all the way back toward your chest the stop would be pushed down the tube to where it could shear off the mike and trim wires. Those wires should go through a hole in the side of the stop sleeve and it should be butted up against the retaining bolts to limit the rearward travel.
    Surprising an annual inspection would not catch an off the shelf switch being used in place of the original. Especially for 8 years!
  • Update: Autopilotcentral was unable to assist. The folks at Maydayavionics were very sympathetic....they are attempting to locate the part for me for a price under $800. Stand by for a follow-up PIREP. FYI: The piece that is broken is the plastic "hat " that sits on the switch. Unfortunately, the part is treated as a single component.
  • OK, thanks for the update.
  • edited October 2019
    I wonder if this would work...
    https://www.aircraftspruce.com/catalog/elpages/trimswitch11-15410.php?gclid=CjwKCAjwo9rtBRAdEiwA_WXcFkaofN7MU0oO2LBJh2KMslpShkRhdeXhHcCxWMxEs7sdsN1pCytMKhoCI-AQAvD_BwE
    Not sure if this means anything or even applies to this application:
    FAA Approved
    PMA NO. PQ2007NM
    And another that says it can be used on certified aircraft:
    https://www.aircraftspruce.com/catalog/elpages/trimSwitches2.php
  • $329 for some molded plastic and a switch...ouch!
    Is there no way to reattach the hat with some superglue or something while you look for a more permanent solution?
    Jim M.
    PA-28R-200
    Based at BUU
    ATC Chicago TRACON
  • I Googled dipole switches and found several including two rocker style the most expensive which was $19.84 plus tax. There is no legitimate reason for a simple switch to cost in excess of $300.00.
  • I had to replace the spring in my yoke switch many years ago. It was finally replaced when the auto-trim autopilot was added. Here is a photo from the replacement drawing.
    https://piperowner.org/talk/uploads/editor/8i/vo09lf2da0as.jpg
  • They say they are machined from aircraft-grade aluminum to eliminate cracking! ;-)
