PA28R-201T winterization plate (77 T-Arrow III)
Does anyone have a picture of the piper engine winterization plate installed on the TSIO-360FB oil cooler? I have been trying to figure out where it goes for the 14 years I've owned this airplane. Thanks in advance.
  • The only real solution is to fly south. ;)
  • edited November 2021
    Here you go! This is from my 1977 turbo arrow III
  • Thank you Scott. Your plate doesn't look like the plate that is stored on my firewall.
    Steve
  • One of them was purchased from Piper and I made the other. But they work perfectly!
  • My Arrow IV turbo does not have a second winterization plate. (Only the one closest to the cowl) Can anyone provide the P/N for the second one?
    Marc
  • Hi, just make one! a "U" shaped piece of aluminum with a hole on one side for a bolt. If you can't make one, have your mechanic make on for you.
