Turbo V band clamp AD
13»
  • I contacted AOPA 2-3 months ago. Gave them all the info and requested help. The said they would investigate and get back. Never heard back and they have not returned follow up questions.
    Ben
  • I just got off the phone with Continental's Region Rep Michael Yousik. He said that these clamps have not been produced in a while. He did say that they have a new clamp in the works, was just at the factory, has seen them and TCM is expecting a release of these in July. And with that, I have decided not to support RAMs Price gouging strategy of charging $1355 each for their PMA'd 2177-300. Mine will come off now for annual and one more time on or before July 16th for the inspection, which should allow continued operations through July 2026.
  • Hi Mickey, and all members who were considering the PMA 2177-300 from RAM.
    I just spoke with a manager at RAM about the $499 price of the PMA 2177-300 V-Band Clamp in April and the $1355 current price. They said they had a price increase on April 11. When I asked why would this clamp now cost nearly three times as much, they basically said because management decided. A non-answer. Then, they noted that the part is PMA for specific engines as if that was a reason for the price. I pointed out the $499 price was also PMA so why the increase? In the end, there were no concrete reasons given to justify the nearly 3X price increase for this clamp. Hopefully a more cost effective solution will come from a competitor, perhaps Continental?
    • Michael Jay Jones (MikeJJ)
  • The AD requires a clamp with more than 500h time in service to be replaced by the July 2025 deadline. So unless yours has less than 500h, an inspection does not give you until July 2026 to replace.
  • I think you are maybe only partially right. I incorrectly stated that I would have until July. The AD says 6 months or 50 hours after the last inspection. The inspection window for clamps over 500 hours ends 24 months after the AD. The way I read it is you have 2 years to do the 50 hour inspections. I do not read a requirement saying you must replace the clamp (with non-existent parts) on or before 24 months. The wording is that you are not allowed to "Install" a clamp with said times over 500hrs after 24 months... With that said, I think I can install an inspected clamp with 500+ hours on 23 months and 29 days after the date of the AD and be in compliance, and run that for 50 hours or 6 months past its last inspection...
    Specifically Paragraph (M) of the AD states...
    (m) Installation Prohibitions
    (1) From the effective date of this AD until two years after the effective date of this AD, do not install a v-band coupling that has accumulated more than zero hours TIS on any turbocharged airplane, helicopter, or engine, unless it has passed all inspections required by paragraph (k) or (l) of this AD. (2) As of two years after the effective date of this AD, do not install a v-band coupling that has accumulated more than zero and less than 500 hours TIS on any turbocharged airplane, helicopter, or engine, unless it has passed all inspections required by paragraph (k) or (l) of this AD. (3) As of two years after the effective date of this AD, do not install a v-band coupling that has accumulated 500 or more hours TIS on any turbocharged airplane, helicopter, or engine.
  • edited May 2025
  • Thanks Mike. I will reply and send my two 18 month old backorder invoices from Spruce and Boeing.
    --mick
  • Email sent. Although I suspect this will fall on deaf ears. Bureaucrats care only about their own rear end, not the potential inconveniences for those pawns they rule over.
  • I also sent an email (Thanks Mike) although I echo Mick's comment that it will likely serve no purpose.
    Ben
  • Update - I actually received a call from and engineer with the FAA. I did not catch his name. He gave me a good bit of double talk and referred me to the FAA Dynamic Regulatory System (DRS) to search for approved PMA parts (I went to the website and if you can get anything useful from it, you are a better man/person than I am). He did not offer any indication that the FAA would back off the existing AD requirements despite the looming deadline.
    Ben
  • Hi greygoose,
    Thank you for the update. Disappointing though. This was a perfect opportunity for the FAA to really help the pilot community.
  • Here's the owner of the PMA part 652333
  • edited July 2025
    David,
    Thank you for the follow-up and passing this Alternate Method of Compliance (AMOC) on to the forum. As stated in the document, this process may be used until April 15, 2026 to comply with the AD during which time new parts and/or other regulatory relief will hopefully become available.
  • Hi David,
    Do you have a good understanding of the implications of the AMOC?
    To my quick read, it sounds like CAT has negotiated (or is negotiating) a volume supplier of the exhaust clamps, to be available in April of 2026. Until then, owners of 360-series engines get a pass on the 500 hour limit, so long as their clamps still pass the 6-month inspections, and are less than 12 years time in service.
    Is that how you read it?
  • Bob,
    In my review, the AMOC only applies to Continental engines, which leaves us Lycoming folks with grounded aircraft.
    Gary
  • Gary,
    it's even worse than that; it only applies to Continental owners lucky(?) enough to have TSIO-360-series engines. Continental TSIO-520 and -550 owners are out of luck.
    I'm curious what the data Continental shared with FAA was that was sufficiently compelling to justify this AMOC.
  • This amoc. Is actually very narrow in scope. And as you've noted only applies to a couple model of engines. It also still requires that you know the time on your existing clamp which I think is a big major hang up for an awful lot of us. It's not something that any of us would normally track unless it came with the engine originally.. but on the other hand it is a start so let's give it some time and see if the feds and perhaps TCM are able to move forward with some other redress for the lack of parts., not to mention like lyc.s too.
    Carl
  • Anyone having any luck getting a clamp anywhere? My plane is in annual and will be grounded until I can find one.
  • Just curious, does the new MOSAIC provide any relief here?
  • Anybody still dealing with this. My clamp has been on back order with airpower. and just today was told it was pushed out again. My airplane is in annual now and it looks like I will be grounded. I am trying to determine if i can use the AMOC until April 15. But if i am reading it correctly I need to be able to detrmine the in service date og my clamp. not sure I can
  • FYI... Aero Mach does not have any
  • so was it at is determined that the Eaton 24540-300 can or cannot be used to replace 653332?
  • Good news. My mechanic informed me that the original V-Band clamp no. 653332 has been superseded by part no. 672127. He said it should be available from Boeing 2/27/26. I’ve been on the wait list since late 2023 so it may take a while to get through the backlog.
  • Good news... 653332 has been replaced with part no. 672127. They are shipping them now!!.. Cost is double.. $750 each. Hartzell just marketed a replacement as well, but looking at the website it does not replace the 653332, and it costs 1,400.
  • Has anyone actually received the replacement v band clamp, part number 672127?
    Just wondering.
    Ben
  • I called Airpower today and they said that Continental recalled all of their new 672127 clamps due to either a design defect or manufacturing defect. They have no ETA on replacement parts.
    Seems like RAM bought the PMA for 653332 and is sitting on them to create scarcity at almost $1400 a clamp.... every other similar V-band clamp is ~ $375
    The Hartzell clamp is a replacement for 67105 and not 653332 and the Seneca III TSIO-KB engine is not listed. It also looks like hot garbage.
    https://hartzell.aero/wp-content/uploads/2026/03/HET-PMA-Supplement-096_Signed.pdf
    Does anyone have a solution? The FAA should either issue a new AMOC or just cancel the original AD as there is really no justification for it in the Seneca series.
    I ordered replacement parts over a year ago for this... some of us it has been two years+
  • Eric,
    Thank you for this update! AND, it is so good to see you back on the forum!! Hope all is well. Don't be a stranger!
  • Thanks - have been running a software company and it has taken all of my bandwidth... I will be out at Oshkosh again this year but likely the later half of the week.
