The FAA is adopting a new airworthiness directive (AD) for certain AVOX System Inc. (formerly Scott Aviation) oxygen cylinder and valve assemblies, and oxygen valve assemblies.
This AD was prompted by reports of cylinder and valve assemblies having oxygen leakage from the valve assembly vent hole, caused by the absence of a guide that maintains appropriate spacing between certain parts. This AD requires an inspection of the oxygen valve assemblies, and oxygen cylinder and valve assemblies, to determine the serial number of the valve, cylinder, and entire assembly.
For assemblies and parts with certain serial numbers, this AD requires a detailed inspection for correct spacing of the gap between the bottom of the packing retainer and top of the valve body on the assemblies, and replacement of assemblies having unacceptable gaps.
This AD applies to AVOX Systems Inc. (formerly Scott Aviation) oxygen cylinder and valve assemblies having part number (P/N) 89794077, 89794015, 891511-14, 806835-01, 807982-01, or 808433-01; and oxygen valve assemblies (body and gage assemblies) having P/N 807206-01.
The AD also points out that you needn’t do anything if you already did during the time of the previous Service Bulletins.
Download the PDF of the AD by clicking here.
