Janitrol Aero heaters will not be affected by the FAA’s proposed AD on South Wind aircraft cabin combustion heating systems which is estimated to impact over 2,500 Piper Apache, Aztec and Twin Comanche aircraft.
Montgomery, AL, (January 31, 2017) — Mike Disbrow, president of Hartzell Engine Technologies (HET), announced that as a result of its asset purchase of C&D Associates in 2016, the company is now producing a line of South Wind replacement heaters under the Janitrol Aero brand.
“Our new Janitrol Aero brand heaters are FAA STC and/or PMA approved and will not be affected by the FAA’s proposed Airworthiness Directive (AD) on South Wind aircraft cabin combustion heaters,” Disbrow said.
Once issued, the AD related to the FAA’s most recent Notice of Proposed Rule Making (NPRM) will require that owner/operators with the affected South Wind heaters (8XXX series and 9XX series), comply within the next 10-hours of heater operating time or next scheduled maintenance activity, whichever occurs first.
The NPRM containing a draft of the current AD is available at: (https://www.regulations.gov/document?D=FAA-2014-0603-0013)
“As written in the NPRM, along with some other inspections and tests, the AD will require a Pressure Decay Test (PDT) on the South Wind heater’s combustion tube. For the tube to pass, it cannot have any leaks,” Disbrow explained. “The FAA estimates that 90-percent of these heaters will fail the PDT. And, according to the AD, any tubes that fail must be replaced. The AD does not allow for any repairs.”
“Should the owner/operator decide to replace the South Wind combustion tube, the AD also mandates that they repeat the compliance testing every 250 hours of heater time or every two (2) years, whichever comes first,” he said.
Disbrow said that while the test is not difficult, there are only a limited number of aircraft maintenance facilities that are experienced and equipped to perform the required testing and compliance procedures. Another challenge facing shops with regards to the PDT is that it is also more difficult to conduct on-wing than on a bench.
“The FAA estimates that there are over 6,300 aircraft affected by this AD – we think that over 2,500 of those will be Piper Apaches, Aztecs and Twin Comanches,” Disbrow said. “Even if some operators choose to disable their cabin heater, there are still thousands of piston singles and twins that will need to comply.”
“If an owner/operator waits until the AD is issued and they fly-off the allotted 10 hours of heater operation time, there just won’t be enough capacity at all the heater shops to handle the deluge of South Wind systems needing testing and repairs,” he said. “That will leave thousands of owner/operators likely facing next winter without cabin heat.”
“There is a way to beat the rush. Hartzell Engine Technologies’ has Janitrol Aero cabin heaters that are FAA PMA approved as direct replacements for the South Wind 8XXX series and for Piper owners we also have FAA STC’d kits to replace the South Wind 9XX series heaters,” he said. “These can be purchased and installed ahead of the AD and will not be affected by the proposed AD when it is issued.”
“By the time you factor in the cost of the South Wind heater AD testing, replacing the combustion tube and the periodic compliance testing, you would pay for a sizeable amount of the Janitrol Aero STC heater kit,” he said. “And any licensed maintenance facility can change out the heaters, which will save the owner/operator a lot of added aircraft downtime.”
South Wind Replacements Charts
Janitrol Aero replacement heaters can be purchased directly from HET or through one of its authorized distributors. Contact information can be found at: www.Hartzell.aero/contact/
About Hartzell Engine Technologies LLC. – Hartzell Engine Technologies LLC, along with its sister company, Hartzell Propeller Inc., form the general aviation business unit of Tailwind Technologies Inc., a growing aerospace technology company. Hartzell Engine Technologies is the leading OEM supplier of aircraft cabin heating solutions and engine accessories, including turbocharging systems, aircraft alternators, starters and fuel pumps. These product lines are produced under the Hartzell, Sky-Tec, Plane-Power, and Janitrol Aero brands. For further information about Hartzell Engine Technologies and its products please visit: www.Hartzell.aero.
